Hey Guys-
I'm not doing well today! I just replaced my clutch plates, and now I have almost no clutch pull. I put the plates in, pressure plate, tightened everything, then grabbed my lever. It pulled all the way in. When I adjusteed my cable all the way out, I got about two inches of pull, but it still doesn't feel right. Now the oil isn't in, and the right case cover isn't on, but I should still have pull, right? What could be wrong. I know my cable is a little worn, but that's not the problem. I checked to see if the cable was attached to the actuator arm, and it is. Any ideas? BTW, I don't want to put the oil in unless I know it will make a difference, because I don't have have very much to waste. Thanks a lot guys
-Stephen
-Stephen
