madmike90
101
its time to re-do the clutch assembly.
my outer basket was very bad, the teeth looked like serated knives so that needs replacing, the plates will be replaced as well. the inner hub looked great so i would like to leave that alone.
what would be the best basket and plates that i could get while still using the stock inner hub?
thanks guys and the application is a 1996 CR125R.
-Mike
Matt90GT
1,517
you can use what ever basket you want with the stock inner hub and pressure plate.
I like the hinson baskets, but do a search on E bay. The PE or Magnum baskets are nice quality and inexpensive. Then I use the Tusk brand clutch kit from Rockymountain or again find it on e bay. The use stock springs. Inexpensive and works really well.
