I have replaced on my 98 KX250 the following:
Basket-new hinson
Clutch hub-stock
Pressure plate-stock
Steels and fibers-stock
Cable-motion pro
I did soak the fibers for a couple days first, have taken it apart 3 times and put it back together, it IS right!
The problem is I cannot get the clutch to disengage, like the plates are sticking?? I warm it up ride around a little bit, try adjusting the cable back and forth(put the new cable on as a last resort) and it doesn't seem to change. It does seem to have the right amount of pull, the pressure plate is coming out a decent distance and I can easily pull the plates apart when looking at it with the cover off. I have done a clutch before and it was simple. Does it just need to be broken-in or do I need to ride it a little harder to get the plates to seperate or what? Going crazy with this bike!
Basket-new hinson
Clutch hub-stock
Cable-motion pro
