I need a little help on this! My kx250 seems a little weak on the bottom and is a little hard to start when it gets to operating temp, about 4 or more kicks out of gear. It starts up normaly when cold. I took a compression reading with the engine warmed up and the throttle full open and the best reading i could get was 125psi. Is this pretty low for a 250? and would this cause the lack of a solid bottom and the hard hot starts? My power valves are pretty clean and the top end only has about 10 hrs. on it. If this is my problem would boring it .080 over and replating bring a substantial increase in the bottom and mid? Thanks for any advise..............
