Dragmeistr
149
I know that this has been brought up previously, but I am at a loss. I have an '03 CR250 and did a compression check on it last night. It only read 100 PSI. I re-ringed the Wiseco piston prior to my last ride and did not have the guage at the time to do the check. I opened the throttle all the way and cranked the thing until my foot hurt. The most I could get out of it was 100 PSI. I know that my cylinder and rings cannot be that wore out. Am I doing something wrong? I did leave my silencer plug in when I cranked it, but that should not affect compression right? Your thoughts and help are appreciated.
Studboy
Thinks he can ride
Dec 2, 2001
1,818
If you can't get air in and out, I think that it will affect the compresion reading. If not, I would look at your gauge. A 250 would be pretty weak with that low of compression.
A-RustyDemon
152
Are you saying it runs with 100 psi reading on your gage? Pull the silencer plug and try it again. If it is running and your still getting the 100 psi reading, check for carbon plugging up the intake in the gage and test it with another gage that is know to be in good working order. Because it should not start if your only making 100 psi.
Dragmeistr
149
I pulled the plug out and tried it again. 100 PSI again. I know that the guage works ok, I used prior to this on my dragster. 12:1 pistons was reading right around 180 PSI, so I know the guage isnt that far off if any at all. Funny part is the bike starts first kick, and runs great. I outran an 01 CR and an 02 KX on the long straight pretty handily. Mysteries of the universe I guess. I will just put my usual 20 hours on the bike and have everything check everything when I rebuild it again.
Studboy
Thinks he can ride
Dec 2, 2001
1,818
There is no way that you are smoking 02 KXs and 01 CR's with 100 PSI!!! So....you must be getting an inacurate reading.
