Dragged the 620 out tonight to give it a once over - it will be a guest bike for my brother in law next week - and wouldn't you know that I rode it about a mile and the clutch went away- no leaks etc I am thinking because it has been sitting maybe there is some air in the system because the seals were dry and stiff andthe first few times it moved it sucked in a little air ? (Magura Hymec)
:bang: Anyway , I have read the posts about bleeding thrugh the bleed fitting with a syringe - I am all set to do that but I have read about mineral oil, fork oil , ATF etc etc
anyone have any input- are these all compatible or will i have to completely purge the old fluid ( sounds like I should anyway)
And how does this stuff happen when the bike is not being ridden anyways :bang:
also , anyone know if he rear wheel bearings on a 96 LC4 would be the same as a 2001 MXC ? I bought the bearings for the 2001 but it turned out it was the shock heim that was the problem- but noticed today the rear wheel bearings on the 620 are toast- would be great if I could use the ones I already bought
