Hi everyone from the Oregon School and those that are not as well. Leapin Lisa just E-mailed me with a riding a question and it made me think I should pass it on to all of you. She was debating with a "guy" rider how to ride in really tight trails that have trees flanking on both sides. He thinks you should sit down and put your foot out on the turns. She on the other hand was not so sure about that and asked me. Here is my response to her. Be sure to Visit the site and look at the pictures. The rider in the picture is a European and they are masters at technique.
1.) If it is too tight that you have to kind of duck to keep from hitting
the trees with your head or shoulders then you would be better off sitting.
Personally I like to keep my feet on pegs for the majority of the time
because it is less work to keep them on the pegs than to take them off and
put them back on. Sometimes sitting is ideal in really tight turns because
you will get better traction which makes you fast. A lot of riders really
romp on the gas in the turns which makes the tires spin. (Because the KTM
has a hard punch on the bottom you tend to spin the tires more - the GG is
more smooth and does not spin but hooks up better in my opinion which makes
you faster) Now what you have to keep in mind when you are sitting is kind
of the same as when you do a turn staning. You want to lean the bike into
the turn but you need to keep you body straight up and down so that you are
keeping maximum weight over the rear tire. If your body leans with the bike
then you can tip over. Go to the following site:
http://www.guillaumeporte.com
From here let the home page download and then pick on English. On that page
pick on GALLERY. When that page comes up you will see small pictures.
There is about 7 pictures. Pick on the top right one. It is a guy (On a
GG) turning while sitting. Notice his body positition in relation to the
bike. The bike is leaning but his body is staying perpendicular to the
ground and his shoulders a parallel to the handlebars. This is how I would
ride through tight stuff sitting. Keep you feet on the pegs. Now if there
was a big huge rutt like at a motocross track then you might consider
putting your foot out and pointing it way forward towards the front tire.
(Most of the time you would never find this in an enduro. Look at the other
picture where the guy is going up a really steep hill and is squatting down
towards the tank like you would on a trials bike to get traction.
2.) If it is not too tight then I prefer to stand and really use my legs to
weight the pegs but this might not give me as good of traction as I want so
I may sit down. If I was going up a hill with tight turns then I would tend
to put my leg out more because I probably would not be going as fast and
would not have the momentum to keep me from tipping over.
I hope this helps anyone who might be wondering. If anyone else has a riding question please let me know and I will try to answer it for you. Ride on.
Nicole
Nicole
