76GMC1500 said:Straight water is ok, you'll actually run cooler with straight water.
76GMC1500 said:Your coolant level shouldn't really change, either. Straight water is ok, you'll actually run cooler with straight water. The only problem is you don't have any of the corrosion inhibiters with straight water and you don't have any freeze protection. Why wouldn't you just drain the water out and refill it with coolant? The bike only holds a little more than a liter of coolant. There are drain screws on your water pump housing and cylinder. Just buy some of that 50/50 mix, look for phosphate free. Get a service manual!
cawkazn said:regular car anti freeze is ok to use?
I was told there was something in it by a professional mechanic that was harmful to quads and bikes other than it being harmful to the aluminum itself.TimberPig said:There is no "sandy" cleaner or anything of the sort in automotive antifreeze, or it would destroy the waterpump bearings there as well.
mmz77 said:I was told there was something in it by a professional mechanic that was harmful to quads and bikes other than it being harmful to the aluminum itself.
mmz77 said:No dont just pull the hoses off unless you are asking for more work and a total mess. There is a drain right on the right side of your case that screws into your water pump cover. Unscrew it and you will be good to go. Make sure when you fill the coolant that you release the air pockets that might form inside your radiator by slighly tilting the bike side to side... :cool:
cawkazn said:makes sense can you elaborate a bit more
fyi everybody I ordered a service manual...so soon the noob questions will stop ;)
cawkazn said:I couldnt find the bolt to drain it. I guess I will have to wait for my service manual.
Before you do anything to this bike I would wait for your service manual to arrive.cawkazn said:wow im a idiot haha...i was looking at the radiatior where i would pour the coolant in. durrrr duh durrr
