Well finally I got everything buttoned up properly (had to swap swing arm bearing collars) and install my new Electrosport Stator so I decided to get some fresh 93 octane mixed with castor 927 @ 32:1. It was a bear to start at first and once it tried to start, had to kick it over a few times but it started right up and idle'd (a tad high at 1.5 turns out on a/f screw). I let the bike warm up for a bout 5 minutes then gave it a few slight revs here and there, and shut it off. Started it back up and turned the af screw 1.25 turns out and it idled perfect, checked the radiators and both were warm so I knew the waterpump is working. Rev'd it up a few times to try and clear it out and it did, but didnt seem to want to rev very high? Anyways I took it for a ride and it didn't want to get on the pipe at first through the gears which is normal until it warms a bit and clears out (usually by 4th gear) and it did, but would not "get on the pipe" then rev'd to the moon wot. Instantly hit the kill switch and nothing, my immediate reaction was put it in first with the rear brake on as hard as i could and try to kill it, it worked! I pushed it home, and went to start it up and it idle'd fine and everything (throttle cable didn't stick) but wont rev up wot and seems to "surge" after a rev and wants to free rev a bit so I kill it. My guess is an air leak on the intake gasket since everything else is new and the bottom end done by a reputable honda dealer, all gaskets are new including one of the intake gaskets, one is old so I'm guessing that would be the air leak source. As far as not gettin on the pipe I'm worried the electric RC power valve isn't working after this stator install (it was fine before), I checked the cables for proper tension and the powervalve itself opened easily. It's putting out plenty of spark, I plugged in the stator wiring with the 4 pin connector and left the other two yellow wires off for the lighting (one is ground one is power). What could be going on here, I'm a bit concerned after I spent more then the bike is probably worth so far rebuilding it. :bang:
