Got an 89 CR 500, the rod is getting kinda slappy in there. I was wondering if I can press the crank back together or if it is like professional, high precision, or just be careful. I've heard of some just pressing it and hitting it with a hammer (doesn't sound quite right to me) but I am wondering if it Has to go to the pros. I have a 55 ton press, and I was planning on actually using our big milling machine because it isn't sloppy. [Just like setting the crank vertical and pressing the other end into the arbor by cranking the table up. Or something like that]
Any help is appreciated.
Thank you
Mike
Thank you
Mike
