yeah your crank bearings are shot the engine needs to come apart as soon as possible the force of the piston moving inside your cylinder in the wrong direction is causing oil to be pumped out of your forks
I was kidding about the engine having to come apart fork seals for your bike should not be hard to find go to a honda shop the wait there will probably be shorter than getting them online
