I’m pulling my hair out over here with a cr85 it was overheating not long after I got it home so I rebuilt the top end the oil was milky and used half the coolant in ten minutes of riding. After the rebuild it did the same thing again head and base gasket were blown and cylinder full of coolant after 10 minutes. I just pull the clutch side case off and the water pump looks fine. Not sure what’s causing this. I had the cylinder and head at s machine shop and they said there was no worping
