morgangdfp
- Dec 31, 2008
- 2
- 0
Hey,
I've got a Honda CR 125 -2006 with a weird problem... I start the engine up and it runs for a few minutes but then dies suddenly and I can not start it again.
I take the plug out and test it but I can not get a spark from it.
And here is the weird thing: I try the same plug on another CR 125 and can not get a spark from it there either..
The spark plug starts to give off sparks again if I let it rest for a few days.
I have two theories:
1. There is something wrong with either the coil or the CDI box that somehow destroys spark plugs.
2. There is something wrong with the fuel/air mixture that makes the spark plug seize to work for a while.
I'm leaning towards alternative no. 2 but would like to know if this is something that has happened to someone else or if anyone has any other theories regarding this.
It might be worth mentioning that this has started to happen about the same time as winter arrived here and I have not adjusted my carburator at all. Should I buy a bigger main jet and see if that solves the problem?
Thanks and a happy new year!!
