The owner's manual shows fork oil capacity is a minimum of 10.8 US ounces (318 cc). Max is 14.0 ounces (414 cc). Standard fork oil quantity is 12.6 US ounces (373 cc).
When working on the forks, the manual says about 12cc of oil will be left in the leg when the tube is left inverted for 20 minutes at 20 degrees C.
