marshef
What affect would putting a CR250 carb on a CR125 have?....It's a 01 Mikuni TMX 11a....on a 99 CR125...I know they put this carb on a 97 YZ125...but with very different jets?....Has anyone experimented with this combination?.....
Mark
TonyJeske
16
It can be done just with some motor work and extensive jetting. A bit pricier than you probably thought. A lot more involved than just putting it on. Just becuase it is bigger doesn't mean it is going to flood your engine.
trial_07
Play with gravity
1,430
Mark
You need to find the right jetting.
trial_07
Play with gravity
1,430
No problem! What is more to say? I've changed a 26mm carburetor for a 28mm carburetor on a Sherco 2.5 (trials bike) and the only thing to do was to find a larger "tube" that connects the air box to the carburetor and find the correct jetting.
