On the later model CR250s (02-05), does anyone have a trick for getting the power valve cables on and off the exhaust valve when doing a top end job? I can't seem to get enough free play in the cables to get the cable ends back into the ends of the exhaust valve, especialy with the tight clearances in the housing. The manual is not very helpful on this point.
On a related note, the manual for my '05 says the cables are self-adjusting via the "spring" on the front cable and the servo motor. I have an old MXA article from '02 that says they are not self adjusting. Anyone know if the later CR250 exhaust valves are self-adjusting?
Thanks.
Thanks.
