I recently bought a 97' CR250. Bike was recently rebuilt with a Wiseco piston, ring, etc. Has an FMF Knarly pipe, and FMF silencer.
I was riding today (only the second ride) in a fairly moderate rain and the bike stalled. It almost got ugly as the rear tire locked up and the tail end of the bike went into a tail slide. Pulled the clutch, got stopped, made sure fuel was on, touched jug and radiator with bare hand and they were hardly hot (I'd only been riding about 5-6 minutes).
The damn thing would not restart and I pushed it home 3 miles. Tried disconnecting the kill switch, pulled the tank and checked electrical due to all of the water, pulled the plug and I am getting spark (plug is dark grey-brown), pulled the carb and disassembled (all vents clear, no contamination in bowl, air checked all passages, found O-ring for air screw to idle jet misinstalled and torn). Checked reeds, closed and opening slightly while kicking, pulled inspection cap from power valve and it is sitting solid at 'L' (won't move with a flat blade, not sure if it should.)
Put it all back together and started kicking again. After a while I got 3-4 backfires from the pipe (silencer off at this point) with a decent blue flame, but wouldn't start....
HELP? :think:
HELP? :think:
