the bike idles hi, then settles down to a low idle after 20 seconds or so, everytime it go's from on gas to idle......
I have cleaned the carb, set air screw, it has a 48 slow jet and I can't recall the main, seems like it was a 125
needle in the 3rd position.
It makes no difference if the bike is hot or cold,
Could it be the float height?
another thing, should you have to physicaly hold the choke plunger up? although it starts fine without the choke ,just thought I would throw that in also
