My 85 yamaha IT 250 has a small hairline crack at the base of the cylinder which is were the front right cylinder base nut is located. It also weepes. Can I get this welded without it cracking again? Thanks.
If you weld the cylinder be careful not to get the cylinder liner too hoe as it will turn blue and get out of round . Also the base of the cylinder should be turned back true on a lathe with an expanding mandrel thru the bore .
Does that mean I have 2 take the cylinder sleeve out of it? Also what are the chances of it crackin again. The crack is only 1 inch long so it wouldont be very hard to weld. Also what is involved with welding a crack. Thanx.
