ok, there is oil leaking from one the bolts holding the cylinder head on. Its not like pouring out but when the bike is running there is like one tiny bubble coming out from the bottom of the bolt. The bolt on tight. any help is much appreciated.
Sounds like a leaky head gasket. Pull it apart and take a look. It won't get better so don't delay. Changing ahead gasket is easy so don't get shy. When you have it apart check for cracks just to be sure.
