jaguar
3 months ago I replaced all the bearings and seals in the crankcase since the needle bearing (the one in front of the output shaft left bearing) #92046-026 had stopped spinning and the shaft was eating through one side of it.
Well the groaning has started again and after taking the clutch cover off I can manually move the clutch up and down with more movement than just the big right side bearing will allow which means the little needle bearing on the far side is going out again.
Any ideas as to why and how I can make its lifespan more than 3 months? thanks
