Since I got this bike I've had issues with the water pump leaking.
Previous owner never had issues with it... :blah:
Anyhow, I first tried just putting a new seal in. That did nothing at all to help.
So, I replaced everything except the seal. Thinking the seal I just put in should be fine. I did note that the shaft was pretty well used up.
New shaft, bearing, oil seal, washer.
Still leaked.
Decided to go ahead and try another seal today. Still leaks.
Anyone have any experience with an issue like this?
I'm baffled. with everything being new, except for the impeller & cover, it should not leak. It's not a constant flow, but it does spit out pretty good.
Still leaked.
