Hi Guy's,
Last year I bought the new 2004 CRF250X, at approximately 1500 KLM'S I put it for a service and the mechanic told me that he found the airbox wasn't air tight as when he washed it, water trickled inside the air box, subserquently this would of let dust in and yes the intake valve had drop considerably. the mechanic went on to say that I would need new valves not to far into the future. Because the mechanic made note of this and also sealed the airbox Honda are doing this under warranty and so they should. My worry is that this might happen again which i will be very disappointed with to say the least. Apparently here in Australia our dust is only 4 microns, which i have been told the bike are designed to deal with 8 microns, so i guess we are behind the 8 ball to start with.
A friend advised me after I get the bike back, I should use the air filter stockings and run a few tanks of av gas through the bike as he believes this will avoid work hardening the valves, yes I have been using valve guard.
I would appreciate any thoughts and ideas on the above and I also realise that CRF250X is a race bike and needs much more attention than my trusty XR400, and it seems worth it when your Riding the little red Roosting Machine.
Thanks in advance
Ben, From OZ
Thanks in advance
Ben, From OZ
