IDkTm
515
Complete specs from Honda:
SPECIFICATIONS
Model: 2002 CRF450R
Suggested Retail Price: $6,299
Engine Type: 449cc liquid-cooled single-cylinder four-stroke
Bore and Stroke: 96.0mm x 62.1mm
Compression Ratio: 11.5:1
Valve Train: SOHC; four-valve
Carburetion: Keihin 40mm flat-slide
Ignition: Solid-state CD with electronic advance
Transmission: Close-ratio five-speed
Final Drive: #520 chain; 13T/50T
Front Suspension: 47mm inverted Showa cartridge fork with 16-position rebound and 16-position compression damping adjustability; 12.0-inch travel
Rear Suspension: Pro-Link® Showa single-shock with spring preload, 17-position rebound damping adjustability, and compression damping adjustment separated into low-speed (13 positions) and high-speed (3.5 turns); 12.4-inch travel
Front Brake: Single 240mm disc with twin-piston caliper
Rear Brake: Single 240mm disc
Front Tire: 80/100-21
Rear Tire: 100/90-19
Wheelbase: 59.4 inches
Rake (Caster Angle): 28.6 degrees
Trail: 119mm (4.68 inches)
Seat Height: 37.2 inches
Ground Clearance: 13.0 inches
Dry Weight: 225.0 pounds
Fuel Capacity: 2.0 gallons
Color: Red
Be sure to check the link too, there is more good stuff there. How about a Ti header? What about that price though $6300, whooo!
Max Factor
155
SWEET :) SWEET :D SWEET !!
I'm STUNNED. That is absolutely gorgeous!!
I Must have one!
55 Hp. How does that compare to current YZ 426 or 520 RFS??
Seperate cylinder / gearbox oil. Who says Cannodale was too innovative now? :eek:
The list is too long, my head is spinning.
I'm fair dinkum excited! This has made my night!
sparkymarky
34
IF it really weighs 225, and IF it starts easier than a yamaha, i predict everyone will have to have one. maybe it'll make ktm 400's easier to find.
mw
dirt bike dave
5,348
It should be a great bike even if it weighs 235-240; my guess at the actual wet/no gas weight. Still a featherweight for a 4 stroke.
I think the scales in Japan must work differently than they do over here.
bashn
65
Add 10lbs for fluids, 12lbs for a full tank of gas, and your at 247 lbs ready to go! That's only 10lbs heavier than a YZ250!
Mark
mtngoat
314
When it comes to ultimate power-to-weight ratios and reliability, Honda's tough to beat. Witness the S2000 (first stock car with over 100hp/liter?), and the CBR600. They're claiming the best p/w ratio among mx bikes. Awesome!
yarbonwick
674
Now if they will only make PWC's. No wait I see that they finally are.:silly:
The new MX looks neat but when will it get a headlight? Says it's not available until October? This is from the honda website: Honda 450R Audio Hear that burble on the decel?
Max Factor
155
That was one of my first thoughts (besides being absolutely stunned, amazed, in awe...)
I am thinking that it may be perspective playing tricks. Normal size pipe on a SMALL bike looks big?
Kind of like your wife having small hands making your .......... well ...... you get the idea :D
