morganbike
- Jan 31, 2005
- 24
- 0
My son races Grasstrack here in the UK using speedway type chassis with suspension on a 400 meter oval .We run a 2001 CR 125 and it is not possible to fit the carb onto the standard inlet manifold as it fouls the frame due to the angle it comes out at.
The norm is to fabricate an inlet manifold with 6mm ally plate,cut a 38mm hole in the centre and then weld on a 38mm tube so it allows the carb to be attached in a more central position.Then attach a 38mm Mikuni TMX carb as close to the reed cage as possible with a length of rubber hose and clips.This set up brings the carb closer to the reed cage than standard.We then fit the biggest K+N filter we can find and jet it up.Standard reeds and cage are used and as the throttle is pinned wide open most of the time the motor is tuned for gating,top end and overrev.
My questions
What difference does the distance the carb is from the reed
cage going to make.
Can this home made tube type inlet manifold restrict the engines breathing capability.
Are there any improvements/mods I can do to make it breathe better ?.
How can I adjust the timing when the stator plate is fixed.
My questions
cage going to make.
