EncyclopediaRonnie
- Nov 8, 2010
- 142
- 0
hey guys so sent my 1993 kx125 cylinder off to be sleeved. nothing outa the ordinary and the pressing of the sleeve seems good as well as the decking and honing to fit the piston however the ports dont all line up dead smoothe. my dilema is if i machine them out to match the alloy where the sleeve was machined the ports will be bigger and possibly change shape in certain spots.
do i a leave it alone the sleeves ports are corect and it will run perfectly normall or do i need to machine the ports all smoothe and even. nothing fowls but im just not sure. im not woried it was a dud sleeve it was a LA sleeve
cheers guys your helps apreciated,
