Hi,
I have a 91 CR500 with 45mm Showa forks. I installed gold valves several years ago and am now riding more agressively. I went to revalve, only to discover I can no longer remove the damper adjuster bolt from the bottom of either fork. Both bolts loosened from their initial tightness (I used a 19mm socket) but neither will back out. Now the damper bolts simpy spin in either direction. They will neither tighten nor back out. Holding the damper assembly with an improvised tool does not help - the damper bolt does not appear to be linked directly to the damper assembly on the 91 Showa. Any advice?
DW
DW
