I have a 92 kx 125 collecting dust in my garage because it had a little incident with the piston and the cylinder wall got damaged. I haven't been too woried about fixing it because I usually ride my xr. Any way the school I started at this fall lets students use the machine shop so I have been wondering if I should try to fix my kx. I am just not sure what exactly is needed to bore out a cylinder. Do you just make it fit the larger piston or do you have to bore it out and then buy or make a sleeve for it. Any advice on this would be much apperciated. The point here is mainly to get a chance to get in the machine shop and learn something, but if I can get my old kx fixed at the same time then great.
