What is the deal? Does the masterlink on this chain really not have a clip? i have never seen one like it but.... Will it be okay, any prolems and what is the proper way to put it on and take it off?
Dang, Rich. You're too fast. Here's a (hot) Link David: http://www.accwhse.com/did.htm Lists both types of master links for that chain (rivet or clip type). I'm assuming you can use either? Rich?
I've never used the ERV2 (I use the ERT or MX) chain so I don't know if there are any potential issues with using a standard style master link in place of the rivet style.
I'm fairly certain you can use a clip type master from an ERT chain for that model. However, I think the the ERT as well as the ERV may have an oversized pin that makes a standard master unuseable.
Did that chain come standard on your new ride, Dave?
How did you get it mounted the first time? Or are you just showing us the back side of the master?
I'm just confused here...not trying to be a pest. :)
