Do I need to use JASO certified "motorcycle" engine oil in my bike?
Jaybird
Apprentice Goon
6,449
Charlestown, IN
It seems many in the motor sports community love to discuss engine oils. And for every legitimate question a rider has about oil, there are normally ten fold the amount of answers. Many of these answers will contain false information to some degree. But, bad info gets passed around so much, and heard/repeated by so many, that misinformation eventually becomes commonly accepted as truth.
More often than not, a manufacturers marketing division will capitalize on any sort of collective ignorance the consuming public exhibits, and use it to their company’s financial advantage. Take for example, the elevated prices we see on oils that are supposedly “Motorcycle Specific” type oils that carry the JASO MA or MB certifications. (Or for that matter, oils that only claim to meet the certification standards, yet have not actually been certified as such)
The public seems to have the perception that these high-priced, aggressively marketed oils must be better than plain old engine oils on the shelf at the service station or auto parts store. They are much higher in price than the car or diesel oils, and that alone tends to say that the product is better…doesn’t it?
Many times these high-priced moto-specific oils will also have pictures of motorcycles on the labels. And the wording on these labels also tells us that these oils are specifically formulated for motorcycle use, which tells us that its better oil than one made for a car or a diesel truck, or does it?
Well, maybe the JASO certified oils are better than shelf oils, and maybe their not. There is absolutely nothing within the JASO certification that points to these “motorcycle specific” oils being any more robust or better than ANY of the oils sitting on the car or diesel marketed oil shelves.
The first thing we must understand about oils is how they are formulated. Engine oils start out with base stock oil. These base fluids are categorized into groups. Currently the grouping of the oils is as follows:
Group I Refined organic crude oil
Group II Even more refined organic crude oil
Group III Crude oil that has been through a hydro-cracking process which “super refines” the crude into a structure nearly as perfect as a lab created synthetic.
Group IV Synthetic base stock created in the lab. This group is reserved for PAO (polyalphaolefin) only.
Group V This is also a synthetic base stock which is lab created, and is reserved for all synthetic bases that are not PAO. Esters and other sorts of synthetic base formulations fall into this category.
Many oil companies will market their oils as being “Synthetic”, when the fact is that only a
percentage of the base stock needs to actually be a synthetic for the oil to be marketed as synthetic.
And when the facts are know, a “full synthetic” oil will contain not only a certain amount of a true synthetic base, but also percentages of the other oil groups as well, including esters and Group I/II organic oils. You won’t find engine oil, be it for a car, diesel truck, or a motorcycle, that is 100% Group IV PAO, even though the label and the marketing campaign leads us to believe that the oil is 100% synthetic.
And only when the formulator goes above a certain percentage of the non-synthetic bases does he have to call the oil a “blend” of both organic and synthetic base stock.
Also, we know that Group III oils were at one time crude oil just like the preceding categories, but this type of stock has been through a hydrolyzing process that refines the molecular structure to a near perfect state. Close enough to true synthetic in the way it performs that it can legally be called synthetic. Group III base has recently been refined by use of some very interesting processes that produce base stocks from organics that rival the performance of PAO. And today many of the synthetic oils we once thought to be full synthetic like PAO, are now being formulated using Group III hydro-processed organic oil.
One thing that all engine oils have in common is the additives.
There are certain products that nearly all engine oils use as lubricants. These additives serve to protect the engine surfaces when the base oil fails, or no longer can protect during extreme conditions. Other additives serve as detergents of sorts, and help to keep the carbon from combustion and other impurities from collecting and forming sludge in the engine.
Very little gets said about the additive package of oils on a TV commercial or product information sheet. Most all marketing is centered on the base of the oil, and hardly ever a mention of the additives. But it is the additive package of oils that makes or breaks them.
The base oil has very little to do with the actual performance of the oil, with a couple of exceptions. Group IV PAO’s have shown that they can withstand the degradation that heat can bring about to the oil. And as such, the synthetic base can last longer than its organic predecessors. But recently it has been proven that the Group III hydro-processed organic base can also withstand excessive heat and extended oil changes.
Group V esters can indeed provide a bit more protection than any of the other bases. These esters are polar in nature, which means the molecules are electronically charged in a way that they are attracted to the metal surfaces and tend to stick to them once they come in contact. This is a great feature for engine oil, since most of the wear we see on our metal parts comes directly from the wear seen at start-up and shut-off. Once the engine is shut off esters will have adhered themselves to the metal surfaces, and are waiting patiently to protect the metal from wear once the engine is started again.
None of the other base stocks can perform at this level.
OK, Back to the myths…
We often hear that we should not use engine oil that is formulated for automobile or diesel truck use. We hear that the JASO certified oils are much better for our bikes.
But the truth is that these $12 motorcycle specific oils may or may not be as good as some of the oils on the shelf selling for $1. There is nothing at all that guarantees us that JASO oils are “good” oils. In fact, the certification allows the oil to be lacking when compared to some of the common engine oils on the shelf. The certification standards for JASO ratings are simply not near as stringent as the standards required for the latest certified oils that are marketed to autos and trucks.
That is not to say that all JASO certified oils are bad…not at all. It only means that there is very little that we can depend on with the JASO certification that says the oil is well built and up to modern standards.
On the other hand, the oils of today that are marketed towards autos and trucks also have a certification system in place by various groups. The standards that oil must pass to carry these certifications are much more stringent than the JASO standards.
Just for an example, I can take oil that had a previous certification of SG (for 1993 year autos and older), and as long as the oil will pass a small amount of tests, I can market the oil as certified JASO oil specifically formulated to provide the ultimate in protection for your motorcycle.
But engine oil that is seeking certification for today’s cars cannot do this. The certification standards have changed throughout the years, and with each new designation a new set of harder to pass standards are required.
The latest certification standards for engine oils are SM and GF-4. These oils are fine to use in older autos that call for previous certifications, since each new certification starts out with having to pass the previous standard, but with added or harder to pass testing included. SM oil has to first be SL oil certifiable, and GF-4 oil also has to be able to first pass the previous standards.
One thing that may be helpful from the JASO standards is the frictional characteristics of the oil. This is an indicator of how well the oil will perform in the wet clutch assembly that most all dirt bikes have. The same oil that lubricated the engine parts also lubricates and cools the clutch, and controls how the clutch acts.
It was seen in earlier years that some inferior oils could actually cause a clutch to slip, or could allow pitting of the gears, and this is precisely why the JASO certification came to be. It was to allow the consuming public an easy way to shop for an oil that would not cause the clutch to slip and was good enough to not cause pitting of the metal gears.
There is absolutely nothing else that JASO certification tells us.
Continued….
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Continued….
The thing is…there just aren’t many oils on the shelf that would cause a problem with the wet clutch assembly to begin with. Sure, back in the early 90’s when the “Energy Conserving” standards came to be that mandated a lowering of ZDDP levels, there were some formulators who immediately started substituting molybdenum disulfide for ZDDP.
This immediately started to show some clutch slipping in a certain model of Honda Goldwing bikes. And right away it was recognized that the molybdenum disulfide was causing a problem. So, molybdenum disulfide hasn’t been used in engine oils for years.
Yes, there is still moly in most of the engine oils of today, including JASO MA rated and certified oils, but the moly used today is a soluble form of moly that causes virtually no clutch variance.
Most of the EC oils that have reduced levels of ZDDP (zinc and phosphorus); will be formulated with proprietary components that the mfg. keeps a secret. Many of these secret ingredients will not show up on an analysis.
The myth that using other than motorcycle specific oil, or using an EC rated oil will cause your clutch to slip is pretty much unfounded. Sure, you may find some oil that may well show a different feeling to the shifting and clutch action, but there are just not many oils that would cause a mechanically sound clutch to slip. More often than not, when a rider’s clutch slips it has nothing at all to do with the oil. It will have more to do with the mechanical condition of the assembly itself.
Another myth is that the lowering of phosphorus (ZDDP) levels in recent years has caused oil to be worse than it used to be. This is completely unfounded and false!
ZDDP is a great additive and does a great job of protecting the metal surfaces when the base oil fails to protect. And the reason it was, and is, so widely used is the price of the additive itself. ZDDP is an easily obtainable and cheap component. But there are many other additives available that will do every bit of good a job as ZDDP, but cost the formulator more money. But to pass the stringent standards to call the oil SM or GF-4, the formulator must use the alternative higher priced additives, or provide one of their secret ingredients to take up the slack of the lowered ZDDP. In may cases the alternative additives perform much better than the ZDDP did.
It was also found that even when lowering the levels of ZDDP, the additional component added would actually interact with the low level of ZDDP and the result was better performing oil than it was previously with the high ZDDP level.
In fact, we can praise the EC certification that came about in the early 90’s because it led to advancements in oil formulations that were previously not known. Or at least not provided to the public because of cost issues.
But there will still be those who state that JASO rated “Motorcycle specific” oils are much better than common shelf oil and heavy duty engine oils. So, let’s look at the standards.
The following is the requirements of engine oil to gain the JASO MA, MA1, MA2, and MB certifications:
Just because engine oil has not gone through the JASO certification does not mean that it cannot pass the criteria for JASO certification. It simply means that the oil is not being marketed towards the motor sports crowd.
In fact, ANY oil on the shelf that is marketed towards cars or diesels, and has a recent certification such as SM or GF-4, will easily pass the meager requirements of JASO T904.
Sure, all oils have slightly varying frictional characteristics, and some may not fall into the JASO MA range if they were tested. And for this fact alone, the JASO standard has some worth, as it lets the consumer know that the oil has been tested and falls into a specific frictional category. With other non-JASO certified oils we must depend on our own testing or the words of other riders who have tested them. But you will be hard pressed to find ANY oil on the shelf that will cause a problem with your wet clutch assembly. That is if the assembly is mechanically sound.
Continued….
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Continued….
Now, let’s take a look at the requirements for an oil to be certified SM:
We see that the SM service category contains a few more requirements than that of the JASO T904 certification. And as long as the components of the oil do not cause a problem with the wet clutch assembly of a bike, SM rated oils should be every bit as good, if not better, than those that only carry the JASO certification…or those that claim to pass the requirements without actually being certified as such.
But the certification requirements of both JASO and the API are not guarantees that these oils are the best products you can use. They are simply minimum requirements of oils to be certified as a particular service category. There are most definitely some oils that are only SM rated that are far better oils than some that are merely JASO certified. And on the same token, there are JASO certified oils that are much better than other oils that are SM rated.
Neither the JASO nor API standards provide the consumer any sort of indication as to which oil is better to use than another. And price alone is NOT a good indicator of an oils worth.
And even more worthless in providing us with the information we need to make intelligent decisions on the proper oils, are marketing campaigns. Only those who really don’t understand the world of marketing will buy each and everything thrown at them by a salesman. The salesman and his advertising accomplices are in the game for nothing more than the bottom line…which is the almighty dollar.
Now, some oil formulators do go the extra mile to provide a superior fluid. And many of these fluids will also reflect very high pricing, but the cost is justified when certain components like polyol esters and high-cost additives are used.
When we consider use of engine oil in a racing four stroke dirt bike, we must realize that there are certain factors that must be accounted for. First and foremost is the fact that oil that is used in both the engine and clutch assembly will see far more contamination than any other sort of engine. This contamination that is primarily created by the clutch materials is far more than the detergent/dispersant qualities of any oil can withstand for extended periods. There is simply too much contamination for the oil to handle. And as a result, we must consider changing out the oil on a frequent basis. And changing the oil frequently in a dirt bike can get expensive, especially if you are using high priced oil.
But what about the oils used in diesel engines? These oils are normally the best at providing contamination control. A diesel engine produces lots of carbon and contamination, and the oils used in them have very high levels of detergents and dispersants to fight wear and degradation caused by contamination. These types of oils also typically contain high levels of additives to help protect the metals in the severe-service, high-torque diesel engine.
There really is no such thing as “diesel engine oil”, but rather oils that are formulated for use in a severe service engine that are called “Universal” or “Heavy Duty” engine oils. These oils can carry an additional service category certification for such extreme duties.
The latest service category for heavy duty engine oil applications is the ILSAC (International Lubricant Standardization and Approval Committee) is the GF4 certification.
Continued….
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Continued….
Let’s look at what is required of GF4 certified oil…
It should be clear to you from the above certification requirements that the GF4 standards are far more stringent than that of either SM or JASO certifications. Heavy duty engine oils are just that…heavy duty. And they are formulated in a way that will serve the needs of four stroke dirt bike engine just fine. This is why we see so much evidence of riders having great luck with the heavy duty engine oils such as Shell Rotella T and Mobil Delvac. Not to mention that the prices of these HDEO’s are very reasonable.
As I mentioned before, just because engine oil states it is JASO Certified, that in no way means it is superior oil. There simply isn’t testing required that would vouch for the quality of the oil or how well it will protect and last. However, when we look at what it takes to provide a certified GF4 heavy-duty passenger car oil, we see that the standards bar has been set quite a bit higher than that of the JASO certified oils.
And again, I am not saying that a JASO certified oil is not a good one. What I am saying is that there is nothing in the JASO standards that would set them apart from other oils, other than the arguable worth of the frictional qualities of the oil.
What I will claim is that GF4 oils are well built, and have testing within their certification requirements that back this assertion up.
Refs:
http://www.api.org/certifications/engineoil/pubs/index.cfm
http://www.api.org/certifications/engineoil/pubs/upload/Technical Bulletin 3.PDF
http://www.api.org/certifications/engineoil/pubs/upload/Technical Bulletin 2.PDF
http://theoildrop.server101.com/forums/showflat.php?Cat=0&Number=721645&an=0&page=1#Post721645
http://theoildrop.server101.com/forums/showflat.php?Cat=0&Number=749606&page=0&fpart=1&vc=1
http://iantaylor.org.uk/papers/future_challenges.pdf
Jaybird
Apprentice Goon
6,449
Charlestown, IN
My posts are full of items that can be nitpicked to death...but my main point is that buying oil simply because it is JASO certified, or high-priced, is a mistake...or its not...JASO standards and high prices are not much of a true indicator of an oils worth.
And we must depend on more than marketing mumbo jumbo and hearsay from A riders to really know what is best to use for our various applications. Although input from any and all true mechanics is invaluable.
(contrary to what the best of dealspeak BS and track mythology would have you believe)
CaptainObvious
Formally known as RV6Junkie
3,331
Jay,
Could you boil all that down to one sentence or just point out the important word or two?
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Sure, Capt... Those who claim that using expensive JASO rated engine oil is cheap insurance for your investment surely haven't done their homework.
Kelvin,
I was using Mobil1 15w50 (old red cap formula) in the thumper, since I have a stash of it. I am now using Shell RotellaT 15w40(GF4) in the 4 stroke and Type F ATF in the 2 strokes (M1 Racing 2T in the tank).
I have been using Pennzoil Platinum 5w20 in the truck. I have been changing the oil ~10,000 miles. I have it analyised each time and it does a fantastic job.
It is now being formulated using Group III. When it first came out it was using an ethylene olefin polymer (Group V synthetic..very rarely used in any oils) for the base.
I have 10K checks on each of the base formulas of them and each look identical.
I also did 10k with Mobil1 5w20 (Group IV PAO synthetic) and there was just a slight tad more ppm of wear metals than any of the PP runs. (PP wins in both price and performance)
BTW...Mobil has been tinkering with their Mobil1 PAO synthetics and are now substituting them with Group III oil. I think their 0w weights and the MX4T are to remain PAO at present.
Mobil will have to reduce their price structure once the word is out to the general public about the base oil changes.
The wifes Exploder gets a diet of Motorcraft 5w20 every ~5000mi (she lets the dealer do all the dirty work, which is fine by moi :) )
MC makes a very good blended oil that should do any passanger car well for 5-7000 between changes.
Solid State
492
Is this true for their 15K extended oils? How can they claim such long change intervals and use less capable oil than their old oil (Mobil 1 5-30 full synth)?
oldguy
Always Broken
We have also been using Rotella Synthetic sinc the Mobil redcap went out of existance inthis area. So far we have had great luck with those 2 oils. This is in 03 and 04 YZ250Fs and an 06 YZ450F. I probably go a bit overboard on the changes doing it after each day of riding whether it is a 6 hour practice session or a 6 moto day.
Jaybird
Apprentice Goon
6,449
Charlestown, IN
What makes you think that the grp III base is any less capable than the PAO? I already have evidence of grp III lasting for over 10,000 miles in my truck and the additive package was still intact and the oil still in grade.
There are several different process' that can produce grp III base, and a couple of them are producing some very fine fluids. And these fluids are much cheaper to produce than PAO. The base fluid is just a building block anyway, as other components are what make the total package.
Jay, where on a label will I find the "group" designation? BTW, great read, thanks for puting together a good analysis.
Solid State
492
I get it now (I think). The new formulation may indeed be superior, but it is certainly cheaper to make so it may now be comparatively over-priced.
SFO
2,001
uh-oh, an oil thread...
Hey Jaybird, waddya think about chevron Delo?
Been using that oil for years.
Jaybird
Apprentice Goon
6,449
Charlestown, IN
Brian,
It is hard for the consumer to know the bases in many of todays lubricants without doing some searching.
Any oil on the shelf that does not state it is a synthetic will be either group I group II or most likely a mixture of the two. I&II are the conventional petroleum oils we have been using for years. Some of these conventional petroleums may also contain an amount of ester or other type of synthetic chemical in the formulation. Not enough to claim a synthetic base, but enough to really add to the performance of the oil.
With oils that claim to be sythetic in composition, we may have to look at the oils MSDS sheet to get a clue as to what the base make-up really is. Mfg's aren't real keen on everyone knowing their recipes and often times will be a bit vague on the MSDS, since they really don't have to list the full formula.
"Highly refined petroleum oil" could fit for either group II or group III synthetic.
The term "ester" could be a multitude of different acids, esters or derivatives.
Word of mouth from insiders who like to spout on the net is the best way to learn what the majority of oils are made of.
Fairly common knowledge that all Castrol synthetic products are now, and have always been, group III hydroprocessed petroleum oil. It seems that Mobil has now started to take the same route with their synthetic lines, whereas all of their synthetic products in the past have been mostly PAO synthetic.
I think it easier to list what we know as to contain PAO now, as to list the ones that don't... Boutique oils like Amsoil, Maxima, Motul, Redline, Royal Purple, etc...still are using PAO and esters in a majority of their formulations...you pay for them dearly too.
Most any 0w car oil will probably be made of PAO.
Heavy duty oils like Rotella, Delvac, and Delo in the 15w40 grade are all conventional oils, while the 5w40 synthetic in those oils will be group III petroleum.
Bill,
I think the Delo is probably one of the finest lubes on the shelf. After all, Chevron owns the additive package company that makes the add packs for many of the top oils of other labels, as well as their own. They make sure that their products are top notch and robust. Their Chevron Supreme passanger car oil is probably the best shelf oil for the buck there is...it's just hard to find.
Some have steered away from Delo in the past because of the higher amount of moly that they use. But, I stand firm on the moly scare being a big load of hogwash for the most part. Moly is a good thing, and it proves itself consistantly.
I've never heard of anyone who actually used Delo to ever report of a problem of any sort.
john3_16
808
I've also heard Mobil started doing this..However, they still carry a PAO price...
Very nice writeup...You did a good job clarifying the distinctions! Pretty much, if someone is going to go spend 5 bucks a quart for Honda GN4 or Kawichem they'd probably be buying an oil that's inferior to plain ole castrol GTX at twice the price..
I've heard that Chevron sells a 10W30 version of the DELO 400 but I've never seen it...Chevron Supreme is a nice oil as well...
rikhek
67
Jay,
I've used the Wal Mart Super Tech 2 stroke oil with TC-3 for years as premix and never had ANY problems over MANY hours.
I just purchased an 05 CRF450R and did my first engine and tranny oil change tonight. I used the Wal Mart Super Tech 10w40 SM service, non energy conserving. I've used this oil in vehicles for years with no problems. Your thoughts?
Rick
This deserves to be brought back to the top so more people get a chance to see it.
Excellent job Jay. :cool:
Thank alot Rich! I was just trying to find a portion of this thread the other day. I was askin Jay about the Rotella/Delo. Great thread. :cool:
Cabot
158
Actually, Oil conversations annoy me. Seems like Everyone is right, but everyone else is wrong.
That was a very long, and 'interesting'(?) read, but it did not change my oil views at all. Because I agreed with most of what it was saying. :cool:
The most important thing about the oil is that you are changing it.
reptikes
Im not to smart and new to bikes, so what are you saying? What oil should i be using in my bike?
Thanks,
Mike
If you have Rotella, Delo or Delvac at your local Walmart those will be fine. Price is great too. I have all 3 here at my wally world.
reptikes
What wieght for the engine and what should i use for my trans. ?
zblink1888
two quick questions is it ok to use a fully sythetic in my yz450 the service manual says nothing about that. and i have a case of 5w-40 that i used in quads and was wondering if that was ok to use the service manual recomends 10w-40 and 20w-50 mainly
FRESH VIDEO
