The end of my exhaust pipe is worn so that it is flat on only about 60% of the circle.The rest is worn about 1/16 so that it doesn't even crush 40% of the crush gasket.Would a second crush gasket help to contour to the uneven section,or would this cause a greater sealing problem?I will be using ultra copper Permatex around the rubber o rings as well to help stop the exhaust leak.Any advice?
