renegade57
I'm liking my 2002 DRZ alot, but I'm wondering if there are any fork tuning options for subduing the impact from hitting square-edged rocks and roots. Will revalving or any other options change the big impact and deflection I am experiencing? Thanks in advance.
marcusgunby
6,450
revalving will improve the fork but ensure you have the correct springs for your weight and have tried using the adjuster to get the best from what you have.
renegade57
I have adjusted the compression and rebound settings optimally with the fork in stock condition. Allthough the springs are stock issue, I am neither blowing through all the travel on those hits, nor am I hardly using travel in those situations. That is why I have inquired about valving. For instance is there a high speed compression valving circuit that can be adjusted or modified to absorb those hits better?
