Santaaa
13
I have a 1980 Yamaha DT100G. The chain that I had for it is bent probably when it popped off due to the old rear sprocket breaking. I want to know 2 things. Should I try to bend the chain back? If not are chains made for specific bikes or are they pretty generic? If I sound stupid asking these questions this is my first dirt bike and I do not know very much about what you can fix and what you have to replace. I figured I would ask to keep anything else on my bike for breaking.
Patman
Pantless Wonder
The chain is "generic". You just need to know the size and number of links to order a new one. You will need a 428 size chain with 118 links, don't forget the new master link as well. No use using the old sprockets either, replace BOTH of them not just the broken one..
Jaybird
Apprentice Goon
6,449
Charlestown, IN
My information tells me that the '80 DT100 uses a #420 chain and sprockets.
Chain #420-(102 links if using stock sprockets)
Stock sprockets are 14/45
Most chains are provided with the initial master link.
Patman
Pantless Wonder
Ah, my bad the 428/108 is for a 125 not a 100. Leave it to the chain master to catch that. The "new master" was a trick I've started to use to get people to have a spare, too many times has my spare ended up on somebody elses chain. :)
dklink2000
764
Here is one I can never remember that might help newbes out. Do you count the master link in the size? i.e if the chain is a 102 link chain....is that with or without the master link?
VintageDirt
Baked Spud
3,043
9
If you count rollers the master link isn't in the equation. Que no¿
Jaybird
Apprentice Goon
6,449
Charlestown, IN
You are absoulutely correctomundo, Mr. V!
First and last reels ARE the master connections.
I agree with Pat...a person would be ahead of the game to buy an extra master link with their chain.
VintageDirt
Baked Spud
3,043
9
I always buy two master links, that way when I cut the chain too short I can scab it back to the correct length. :)
