Electric dirtbike vs. gas dirtbike !!!
jumpingjoe628
176
The other day I saw an interesting clip in the "Video on demand" feature on Comcast cable. It was in the tech tv section called "gaming desktop" along with other cool gaming computer clips, it was the electric dirtbike called the Blade. In the video they were riding on a hardpacked motocross track going through REAL whoop sections and hitting jumps that had to be at least 30-40 feet long. I was impressed !!! It only has 18 rwhp but it out performs a 2004 XR 250 from 0-30 mph and it is all touque. The Blade is more money than a conventional dirtbike upfront at around $8400 w/ a 20 min charger but think.... no gas, no oil changes, no topends, no valve adjustments and you can get away with riding it virtually anywhere because it is super quiet. With the current batteries it only last an average of 20 minutes and has a top speed of 45 mph which be good enough for now but only time will tell when they start breaking out the Lithium batteries. New gearing will help with top speed also. So what do you think?
acanz
195
Yeah I'll wait until they can keep up with a gas dirtbike before even considering one. Cool idea, but gas is still better then electricity as of now.
jumpingjoe628
176
I agree with the fact that gas bikes are faster, in fact isn't that the reason we all are in this sport, to have fun, and Speed is really fun. Though, living in New Jersey makes it real hard to ride when and where you want to so this new bike looks to be my next when my CR 250 is no longer economically viable. For me there are a lot of factors that are leaning towards the Blade bike and I'm real excited to see it progress like the gassers have in the last couple of years.
gowen
210
It looks and reminds me of a nice bicycle with a battery and a heater fan motor. I'm not impressed, but will consider it, like everybody says, when it can put out 50+hp.
jumpingjoe628
176
50 HP ?!!! what are you insane! To match todays bikes in the 250 class the electric bikes would only have to make 35 HP. That would make the power to weight ratio the same. As it stands right now the "Blade" can out run an xr 250 from 0-30 by a half second with an 18 HP motor. Imagine what it could do if it had 35 HP.
acanz
195
An XR250 is not a full-on MXer. The XR250 probably makes 20-25 HP while a CR250 will put out nearly 50. The "Blade" is making nearly the same power as the XR, just its light weight lets it get off the line faster then an XR250. At 35 HP, the "Blade" <i>might</i> get off the line faster in a race, but by the first turn I would be suprised to see it anywhere but last.
Glitch
630
Being an electric motor, wouldn't torque be a better thing to look at. That is why trains use them, because you can get 100% of the torque right after 0rpm(pretty sure). Traction control, if so desired, would see more possible than with a gas engine. When a sensor senses that the back wheel is spinning freely, it would be easier to tell an electric motor to slow down than a gas one, or better than the brake slowing it.
It says it has over 250 ft/lbs torque at real wheel????(doesnt sound right) What does a 450f have?
jumpingjoe628
176
If you have Comcast cable service you can see it in action. Just go to the "On Demand" feature and select "Cutting Edge" - "Tech Tv" - and then "Gaming Desktops". And I think this is older footage probably when it first came out.
splatt
Resident mental case
908
16
If the cost wasn't so high as compared to a gas powered bike I think it would be a blast to ride in areas where the gas bikes aren't allowed.
Steve
Oct 10, 2004
163
Glitch was correct when he said that electric motors develop the most torque at startup. as for the 250 ftlbs at the rear wheel that does sound correct if they are factoring in the gearing, because lets say your street car has 100 ftlbs torque and your trans had a 3:1 ratio in first and yout real end had a 3:1 ratio then at the rear wheels you whould have 900 ftlbs torque. if lets say the blade had a 12 tooth front and a 51 tooth on the back that would give it a 4.25:1 Final drive ratio not including the transmission seeing as though it only has a top speed of 40 mph I think the actual gear ratio must be alot higher lets say the motor made 20 ftlbs at the crank then to acchive 250 ftlbs at the rear wheel it would need a total gearing ratio of 12.5:1. I hope i didnt confuse anyone too much with the post as I am kinda skatterbrained as for my opinion on the bike i think it is kinda cool and a good idea. but dont you think it would be weired seeing someone fly past you without making a sound except for the air moving around them
Feb 20, 2004
241
also not to mention hearing them scream when they are about to crash into a tree. :yikes:
SpeedyManiac
2,374
Another thing, I think it looks more like a mountain bike, the forks look like they're off of a mountain bike, same with the brakes as well as the wheels. Not sure on the shock.
wardy
2005 Lori Nyland Award Winner
Nov 12, 1999
2,681
9
yep and you know someone will just have to put cards on the spokes so it will be "louder" then the other guys.
wardy
xsnrg
728
I was thinking the same thing, but they are also a lot lighter overall than a gas engine dirtbike, so they don't need the beefy frames and forks to absorb the same landings a gas dirtbike would. But, until they can run for 5 hours at a time for a good trail ride, I'm not interested. I think though that if you lived in town, it would be cool to make a mini MX track in your back yard and just go out back and mess around on it. But $8k is alot of jack to shell out for a backyard playtoy.
holeshot
Crazy Russian
1,822
Or the scream when they're electrocuted while riding through a water obstacle.
kevinfries
14
There was a thread about this on a different forum, and there was a link to a cnn article or something, It said that they were trying to make it have artificial engine sound so you can hear it. I think it will be a good thing once it is improved upon, why not just use a larger motor? How will the classes go? Now it will be between 4strokes,2strokes, and electric!
jumpingjoe628
176
I would gladly pay $8k for it, if it improves. Even though I cant afford it lol. You'll save in the long run. As long as it can do all the jumps at a MX track I'll be happy.
acanz
195
I dont know many people that send their engines to a shop whenever they overhaul the top end, because thats the equivalent of what your saying about overhauling the motor. If the motor burns out, if your lucky you could get it professionally rewound (cant do that yourself), or if your unlucky its trashed and you need a whole new motor.
