While I am fairly handy this all seems to be getting out of hand in compexity.
I have a 99 RM250 that posted a compression PSI of 185.
So after reading that 250s should be in the 235-250 range I decided to rebuild the top end.
Sometimes it seems simple sometimes it seems extremely complex.
OK, tearing down the cylinder and getting the piston and rings off sounds reasonable.
These parts worry me.
1) tearing down the power valves to clean them since there is no Clymer for my bike how do I know how to take it apart and put it back together?
2) Honing the cylinder??? I saw where I can get a tool for $31 but this seems like a tough machining process. Do ALL cylinders need this?
3) Piston size. I ASSUMED I'd need std. but you are saying there are varying sizes notated via A,B,C,D etc? and if the cylinder is worn I'd possibly need a different letter piston then my bike came with? I have a micrometer and dial calipers but what is being measured here?
4) Some people say to have all the parts first but how do you have any idea what you or don't need until you get in there?
