KawieKX125
- Oct 9, 2000
- 946
- 0
I replaced the rod kit in my 2001 KX125 since it was beat. The crank was rebuild by my AMI trained friend and it was trued to under.001". We installed the crank into new Moose bearings with the puller tool and the kawasaki wedge. It went together fine and seemed to center itself as we heard a large POP when the cases were tightened(Eric, you describe this in your book I believe).
So I finished putting the external motor parts on and when I started it, it siezed in a matter or revs. Probably went around 20 times and stopped up.
I tore it back apart and it has a really, really wierd problem. The crank managed to jam itself against the left side case. It recentered itself to the left of the motor for some reason. What would cause this? Can I just use a dead blow hammer and a punch on the crank centers to recenter it in the cases, or do I need to tear the motor back apart and do it all over?
BTW, the rod kit was a Hot Rod and the bearings were Moose(i mentioned that I think).
Thanks for your help!
