I don't know for sure, but is there a KX hub that shares the same part number as the KDX. They make them for most MXers. I had to do that to get some stainless spokes for my DR. I found out that the RM spokes were the same. So I ordered them and they work great. I also found out that the YZ and the DR share the same part number from Excel. Good luck.
Danman is correct, Kawasaki uses the same hubs on there dirt bikes, if you get a KX hub, you will have to change the wheel bearings and spacers to the size of the KDX axle, the front is going to be different because of the ODO, if you lose the ODO then you can use a KX front hub.
