http://www.machinedesign.com/ASP/vi...76&strSite=MDSite&Screen=CURRENTISSUE&CatID=3
Any idea who the manufacturer is and what models are affected?
sixds said:so buying a 2000 or 2001 yz would be a bad idea????
the throttle stuck wide open as the rider made a jump
While exploring obvious weak areas of the throttle design, engineers concluded that a flawed rotor the throttle cable rode upon caused the throttle to stick
On certain vehicles, a loose or bent inner throttle cable wire may derail off the rotor in the throttle housing on the handlebar. If this occurs, the throttle cable could be pinched between the rotor and the housing, causing the throttle to stick.
