derek the 2 stroke
- May 5, 2007
- 102
- 0
My bike throws spooge all over the engine and swingarm,it looks horrible,so i figured it was time for a topend so i repacked the silencer and put in new piston and rings.And it didnt fix the problem.It stills spooges everywhere,especially when you run it hard,so I figure its time to rejet it.And i know its trial and error but any suggestions would help alot cause ive never done this.
My stock settings are:
Air screw-2.0 turns out
Slow jet(I guess thats the pilot jet)-#50
Jet needleF1240g 24naaj
needle clip position-3rd groove from the top
Main jet-#125
Float level-0.75
I thing my problem is my main jet cause it does it worst when you run it hard.It never fouls plugs but im running a Br8es instead of the recommended Br10eg.
My manual suggest for my altitude and Temperature(2500-4999 and 59-80 degrees farenheit)
Air scrw-2 turns out
slow jet-48
Needle clip position-2nd from top
Main jet-122
Also it says a rich condition can be caused by an air leak,My bike occasionally backfires when trying to start it.
But do you think the rcommendations sound about right or should i just go down until i get it right?
It also says honda jets do not co-respond with other manufaturers jets.
Its a 2002 cr 80 Bone stock exept weisco piston.
Main jet-#125
Float level-0.75
slow jet-48
Main jet-122
