markymark77
- Jan 4, 2002
- 80
- 0
Well while slapping my plastic back on my 02 CR 250, I un nesesarily cranked one bolt holding the right side pannel on so tight that I stripped the bolt hole:scream: WHAT WAS I THINKING!!! Anyway is there a way I can fix this? It looks like a nut has been spot welded onto the sub frame. SO either I can grind off the stripped nut and have a new one welded on or drill it out and install some sort of insert in order to use the same factory bolt.If I had the nut ground off the sub frame & replaced, would it have to be the same alloy as the sub frame? :uh:
