chevy383cid
- Aug 26, 2005
- 307
- 0
Hello Everyone, I have a 02 KX 250, That has slowly developed a flat spot ,in only high gears,When riding hard, it wants to take it's time going in to the powerband only in high gears!! Compresion is good, plugs always look pretty good, I keep the air filter clean,silencer has fairly new packing,I run belray H1r at 32:1 with 93 octane,I have a JD jetting kit with a 45 pilot,168 main and the blue tip needle in the 3rd(middle clip position)Now in low gears it does outstanding Its just that on long pulls up hills is where this flat spot appears. Does anyone have an Idea what could be the problem,moving the clip down to make it a little richer or makining it a little leaner by going up on the needle, or relieving some of the spring pressure on the powervalve ??
