in eric gorrs book it shows how to set the floats , i was wondering about the bar that connects the floats and depresses the valve or needle.the little tongue that pushes the valves plunger is bent down and then bent again at a light angle that is almost flush with the bar connecting the floats to the carb. is that normal, gorrs book says that to set the floats you should make the horizontal mark parralel with the carb body when the needle or valve is seated and the plunger is fully extended. mine is at about a 20to 30 degree angle could this cause my lean jetting.
