I'm riding a 1990 KDX200 with PC pipe and silencer and airbox mod. In Tallahassee it's 70-80 degrees with high humidity. My mixture is 35:1 and jetting is 38 pilot, cel 2nd from top and 152 main. The question is regarding a mid throttle bog at what I would guess to be at 3 to 4 thou. rpm. I was thinking about going to the middle clip, but wonder if lowering the float from 17mm to 16mm might have an effect?? Or should I go with a bigger slide cutaway? Whan I'm on the pipe it will stand up in 4th gear. It's run running great, but I'd like a little more control at lower rpm's. Thanks, Jay
