harescambler
- Jun 3, 2002
- 23
- 0
99 wr 400. race tech susp. but do not know the valva stack. It was on the bike when I bought it. .46 spring rate and has the gold valves. Problem: (1) rides low in front may need shimmed. oil level is at 95mm. Problem (2) down hills with braking bumps nearly vibrates the bars out of my grip. More rebound needed?less?
Will setting the race sag with shims help this along with minor adjustments? The bike does good on most obsticles. It does seem to have a hard hit toward the bottom though. Any help apprec.
