Coach in ND
212
I need some Mobil 1 to rebuild a set of forks and a shock for this weekend but can't find any locally. Can I use and full synthetic ATF?
Also I have Race Tech Gold Valves installed...should I valve different with this heavier fluid?
2001 KTM 400SX #529
2000 SVCC 125cc H.S. #1
SPONSORS: MA'S CYCLE, SIDI, WD-40, ACERBIS, SMITH, SPROCKET SPECIALISTS, N-STYLE, WER, DEVOL.
JTT
1,407
I've never used others besides Mobile 1, but if you check a recent post here "Problems w/Mobile 1 ATF", Shocknut have looked into others apparently.
As far as setting, you will find that you will have to go a couple of clicks softer to compensate for the slightly heavier weight, but will find a greater range of clicker adjustments.
JTT
No matter where you go...there you are
