Hey all..
I am currently replacing my fork oil and springs. do you know if i have to bleed my forks for trapped air at all once they are all back together ? may be a silly question but wasnt quite sure.
if you are taking the forks completly apart then just follow the instructions in the manual. It will tell you everything you need to do to get the air out,
When I had them apart, I just set the oil level to my liking then pumped them all the way up and down to get the trapped air from under the piston, then put them back together and on your first ride, keep cracking the bleeder and letting any more air out. No big deal.
