racing_46
17
After going away for the holidays my 1995 KDX 200 was left collecting dust in the shed and when I returned to take her for a spin I noticed the fork seals were leaking quite badly, they had a minor leak before I left, but what I was wondering how much a pair of fork seals cost and what fork oil would you guys recommend using when replacing them, and one other thing what would the cost be of a new set of clutch fibres, as they are in need of replacing. Any help would be greatly appreciated.
Thanks in advance
cweingartz
241
Fork seals range from $10 to $30 us dollars depending on the quality of the seal. I think they have 10wt oil stock.
Clutch discs are around $40 to $50 us.
KDXMAC
79
dude ring your local Kawa dealer for prices but have the fork seals done at a different bike shop as I have found dealers to be more expensive, this is assuming you don't have the tools to change the fork seals yourself.
Good luck
Mac
canyncarvr
4,005
To remove the seals you generally y-a-n-k the tubes apart..using the sliders to push the seal out from the inside.
That generally ruins the sliders. Dings up the teflon coating pretty good.
Sliders aren't cheap!
MX-Tech recommends Mobil-1 ATF for home fork service. Well..they used to, anyway. Couple years back.
Braahp
641
Sounds like your seal may need replacing. A little trick to try first though is to take a piece of 35mm film and wedge down between tube and seal. Slide this around tube a few times. Usually it will dislodge any dirt that might have found its way in there and causing a leak. Works 99% of the time, but if your seals are shot they are shot. Its worth a try.
