rmrider45
171
:whoa: :who:) :) :) :) hi. i found a 2001 rm 125 bottom end and was wondering if my cylinder from my 2003 rm 125 would fit and also would the 2001 bolt up to the frame the same as my 2003. .the motor i found the connecting rod has no play up and down and seems in good shape..also what is the bottom end worth complete .
julien_d
1,788
Not sure if your 03 cylinder will fit. Best way to find out is to check parts fiche and see if the part numbers for the cylinder match from 01 and 03.
What's it worth? Again, no clue. What's it worth to you?? Why are you shopping for a bottom end? It's cheaper to rebuild one than to buy a used one and end up having to rebuild it as well.
rmrider45
171
it has a new hot rods crank installed already. crazy thing is that i cant get the bike into
Neutral the bike always ran fine i drove it many times.the bottom end is in the bike atm no top . will i be able to start the bike in a high gear? when i took it from the doner bike it was in Neutral.
FRESH VIDEO
