I found a 01 KDX 220 locally and the guy is asking $2200. It has a bunch of new stuff: gold valves, carb professionally redone (bored, modified slide, etc). It almost sounds too good. The guy tells me it has "bend" in the rim where he hit a rock really hard on a downhill, and that the rear sub-frame was bent, but he just bent it back. Anything sound fishy, or is this a steal?
"I have done lots of work to it as well. The frond suspension has been rebuilt with stiffer springs and gold valves are installed. Drivetrain is all new. Renthal bars with guards and front light as well. I've polished a lot of the parts I put on as well. Pipe and silencer are in good shape. Bike is very clean and fast. I had the guys at RB carb designs bore it out, rejet it and modify the slide plate inside. "
"The sub frame in the back was bent a little but I just simply bent it back to get things to line up. The only thing I did not get a chance to replace are the rims. There is like one minor bent in the rim but is barely noticeable when you see it.(Hit a rock going too fast downhill)"
Opinions please!
Opinions please!
