I just installed a fredette torque ring. I noticed one of the o-rings on the exhaust pipe is no longer in the head.The bike is a little louder.Will this hurt anything? Any way to help seal the exhaust?
I could not really tell the difference after installing a torque ring. Then again I plan on putting one on my recently purchased KDX. Ok Ok I thought I could tell a little.
I think I will also try some high temp silicone as suggested if I can't get the o rings for my FMF pipe.
93 kdx200
91 kdx200 that needs a rear wheel
tom :silly:
I just installed a torque ring before I went to Stoney Lonesome this past weekend. I thought I could tell a difference it came off the bottom a little stronger. For the cost it does not hurt to try one
vibguy1,
do you also have an aftermarket pipe? I wonder what would happen if you put a torque ring on a FMF Gnarly "Torque"pipe. Overkill? Or put one on a Gnarly "Rev" pipe.
